在识别颜色时有时出现帧超时是什么原因呢?
# Untitled - By: Lenovo - 周三 9月 27 2023 import sensor, image, time threshold_index = 2 # 0 for red, 1 for green, 2 for blue thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds (30, 100, -64, -8, -32, 32), # generic_green_thresholds (41, 64, -20, 6, -44, -28)] # generic_blue_thresholds sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() while(True): clock.tick() img = sensor.snapshot() for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200,area_threshold=200,merge=True): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(),blob.cy()) print(clock.fps())
