  • 通过小车供电,接上地线和5V电压,却会在闪黄光之后闪红光。这是为什么呢?
    • import sensor
      import ustruct
      import sensor, image,math,pyb,ujson
      from pyb import LED
      sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
      sensor.skip_frames(time=2000)  # Wait for settings take effect.
      red1_404 = (31, 58, 48, 74, 20, 50)
      red2_402 =(34, 64, 23, 65, 5, 39)
      red3_402 =(32, 74, 23, 68, 7, 39)
      red4_402 = (31, 58, 48, 74, 20, 50)
      red5_402 = (32, 74, 23, 68, 7, 39)
      red6_404 = (31, 58, 48, 74, 20, 50)
      #red1_404,red2_402,red3_402,red4_402,red5_402,red6_404
      green1 =(63, 88, -44, -9, -128, 127) # green_thresholds
      green2 = (20, 61, -128, -11, -128, 127)
      green3 = (20, 68, -128, -11, -128, 127)
      green1_402 = (53, 100, -128, -11, 0, 36)
      green2_402 =(53, 101, -128, -11, 0, 36)
      green3_402 =(53, 100, -127, -11, 0, 36)
      green4_402 = (53, 100, -128, -12, 0, 36)
      green5_402 = (52, 100, -128, -11, 1, 36)
      green6_404 =(39, 92, -128, 5, -17, 34)
      #green1_402,green2_402,green3_402,green4_402,green5_402,green6_404
      blue1=(0, 27, 5, 127, -128, -19)# blue_thresholds
      blue2 = (0, 28, 0, 127, -128, -16)
      blue3 = (0, 28, 4, 127, -128, -19)
      blue1_402 = (25, 65, 12, 44, -74, -41)
      blue2_402 = (25, 65, 12, 44, -74, -41)
      blue3_402 = (25, 65, 12, 44, -74, -41)
      blue4_402 = (25, 65, 12, 44, -74, -41)
      blue5_402 = (25, 65, 12, 44, -74, -41)
      blue6_404 =  (25, 65, 12, 44, -74, -41)
      #blue1_402,blue2_402,blue3_402,blue4_402,blue5_402,blue6_404
      #初始化变量
      uart = UART(3,115200)
      pi=3.1415926
      data = 0x00
      tx_data = 0
      gray_ground1 =(3, 44, -10, 8, -15, 5)
      gray_ground2 =(0, 67, -15, 25, -35, -9)
      rx_buff=[]
      state = 0
      def Receive_Prepare():
          global data
          global state
          if(uart.any()>0):
             data=uart.readchar()
          if state==0:
              if data == 0x0d:#帧头
                  state = 1
                  state = 0
                  rx_buff.clear()
          elif state==1:
              rx_buff.append(data)
              state = 2
          elif state == 2:
              if data == 0x5b:
                  tx_data = int(rx_buff[0])
                  state = 0
              state = 0
              rx_buff.clear()
      def sending_data(cx,cy,c,R):
          global uart
          data = bytearray([0xFF,0xFF,cx,cy,c,R,R,0xFE])
          uart.write(data)   #必须要传入一个字节数组
          print("send data")
      def find_max(blobs):    #定义寻找色块面积最大的函数
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
      def receive_color_and_send_message(color_threshold1,color_threshold2,colorthreshold3,colorthreshold4,colorthreshold5,colorthreshold6):
          #检测物块位置
          global tx_data
          sensor.skip_frames(time = 1500)
          sensor.set_vflip(False)
          sensor.set_hmirror(False)
          while(tx_data == 1):
              blobs = img.find_blobs([color_threshold1,color_threshold2,colorthreshold3,colorthreshold4,colorthreshold5,colorthreshold6],pixels_threshold=13000)
                  max_b = find_max(blobs)#找到最大的颜色矩形
                  #img.draw_rectangle(max_b.rect())
                  #img.draw_cross(max_b.cx(), max_b.cy())
                  x = max_b.density()#显示颜色的可靠程度
                  if(x<0.3):
                      c=1
                  elif(x>0.3 or x == 0.3):
                      c=2
                  cx = max_b.cx()
                  cy = max_b.cy()
                  pyb.delay(10)#拉长数据发送时间,让芯片来得及处理数据
                  sending_data(cx,cy,c,1)
                  Receive_Prepare()
                  #print(cx)
                  sending_data(0,0,0,0)
                  Receive_Prepare()
      def jiaozhun():
          global tx_data
          while(tx_data == 4):
              for circle in img.find_circles(threshold = 4000,r_min = 30,r_max=40, x_margin = 5, y_margin = 5, r_margin =1, r_step = 2):
                  img.draw_circle(circle.x(), circle.y(), circle.r(),color = (255,255,255) )
                  area = (circle.x()-circle.r(), circle.y()-circle.r(), 2*circle.r(), 2*circle.r())
                  cx=circle.x()
                  cy=circle.y()
                  cr = circle.r()
                  c = 1
                  R = 2
                  print("cx is ")
                  print(cx)
                  print("cy is ")
                  print(cy)
                  print(cr)
                  receive_data()
      def whether_pingxing():
          global tx_data
          while(tx_data == 5):
              blobs = img.find_blobs([gray_ground1,gray_ground2],pixels_threshold=11000)
                  img.draw_rectangle(max_b.rect(), color=(0,0,0))
                  #print(max_b.rotation()*180/pi)
                  Rotation = int(max_b.rotation() *360/pi)
                  if(Rotation >180):
                      Rotation = abs(Rotation - 360)
                      R = 1
                      R=0
                  Distance = max_b.h()
                  sending_data(Rotation,Distance,1,R)
                  print("rotation we send is ")
                  print(Rotation)
                  #print("distance we send is")
                  #print(Distance)
                  receive_data()
          Receive_Prepare()
          if (tx_data == 1):#red
              print("here 1")
              red()
              receive_color_and_send_message(red1_404,red2_402,red3_402,red4_402,red5_402,red6_404)
          elif(tx_data == 2):
              print("here 2")
              green()
              receive_color_and_send_message(green1_402,green2_402,green3_402,green4_402,green5_402,green6_404)
          elif(tx_data == 3):
              print("here 3")
              blue()
              receive_color_and_send_message(blue1_402,blue2_402,blue3_402,blue4_402,blue5_402,blue6_404)
          elif(tx_data == 4):#检测圆心
              print("here 4")
              green()
              jiaozhun()
          elif(tx_data == 5):
              print("here 5")
              red()
              whether_pingxing()
              print("bad data")
