  • 颜色识别怎么才能更准确啊?感觉特别容易识别错,极受光线影响
    • # Multi Color Blob Tracking Example
      # This example shows off multi color blob tracking using the OpenMV Cam.
      uart = UART(3, 9600)
      uart.init(9600, bits=8, parity=None, stop=1)
      # The below thresholds track in general red/green things. You may wish to tune them...
      thresholds = [(0, 100, 45, 127, -128, 127), # generic_red_thresholds
                    (59, 100, -79, 38, 33, 82), # generic_green_thresholds
                    (4, 68, -19, 103, -109, 127),# generic_blue_thresholds
                    (0, 14, -44, 8, -59, 29),# generic_black_thresholds
                    (60, 100, 0, -93, 8, -82)] #generic_white_thresholds
      # You may pass up to 16 thresholds above. However, it's not really possible to segment any
      # scene with 16 thresholds before color thresholds start to overlap heavily.
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
          for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200):
              #if blob.elongation() > 0.5:
                  #img.draw_edges(blob.min_corners(), color=(255,0,0))
                  #img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  #img.draw_line(blob.minor_axis_line(), color=(0,0,255))
              #img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)
          #print(clock.fps())
          print(blob.code())
          #uart.write("%x" %(blob.code()))
          X=int(blob.code())
          data = bytearray([0xa5,X,0x00,0x00,X,0x5a])
          uart.write(data)
