sensor.set_framesize(sensor.B128X128)
sensor.skip_frames(10)
sensor.skip_frames(time = 5000)
NUM_SUBJECTS = 2
NUM_SUBJECTS_IMGS = 3
img1 = None
pmin = 999999
num=0
def min(pmin, a, s):
global num
if a<pmin:
pmin=a
num=s
return pmin
uart = UART(3, 115200, timeout_char=1000)
num = 0
objects = img.find_features(face_cascade, threshold=0.75, scale_factor=1.25)
for r in objects:
if(r):
img.draw_rectangle(r,color = (0,255,0))
cx = r[0]+r[2]/2
cy = r[1]+r[3]/2
print('x:%d, y:%d, w:%d, h:%d' % (r[0],r[1],r[2],r[3]) )
print('cx = %d, cy = %d' % (cx,cy))
img1 = None
pmin = 999999
num=0
dist = 0
for i in range(1, NUM_SUBJECTS_IMGS+1):
img1 = image.Image("singtown/s%d/%d.pgm"%(s, i))
d1 = img1.find_lbp((0, 0, img1.width(), img1.height()))
dist += image.match_descriptor(d0, d1)
pmin = min(pmin, dist/NUM_SUBJECTS_IMGS, s)
print(pmin)
print(num)
uart.write('X%dY%dN%dOK\r\n' % (cx,cy,num))
break
uart.write('X-1Y-1N-1OK\r\n')
