  • 这个代码的串口通信有问题吗?ttl口不接收?
    • 请在这里import sensor, image, time
      from machine import UART
      import math
      # 颜色阈值
      thr_write = (60, 100, -20, 20, -20, 20)  # 白色阈值
      thr_black = (0, 35, -20, 20, -20, 20)    # 黑色阈值
      # 初始化摄像头
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)  # 关闭自动增益
      sensor.set_auto_whitebal(False)  # 关闭自动白平衡
      # 初始化串口 (与main.py保持一致)
      uart.init(115200, bits=8, parity=None, stop=1)  # 明确设置串口参数
      # 图像中心坐标
      img_center_x = sensor.width() // 2
      img_center_y = sensor.height() // 2
      # PID参数
      Kp = 0.9   # 比例增益
      Ki = 0  # 积分增益
      Kd = 0  # 微分增益
      # 发送数据相关变量 (与main.py保持一致)
      Servo_dx = 0
      Servo_dy = 0
      Servo_data = [0,0]
      # PID变量
      last_error_x = 0
      integral_x = 0
      last_error_y = 0
      integral_y = 0
      # 通信协议定义 (改进版)
      HEADER = b'\xFF'  # 包头 (字节类型)
      FOOTER = b'\xFE'  # 包尾 (字节类型)
      # 目标参数
      target_offset = [0, 0]  # 目标补偿量
      target = [0, 0]         # 目标坐标
      view_offset = [0, 0]    # 视角偏移补偿
      target_valid = False    # 目标有效性标志
      # 发送数据包函数 (修复版)
      def send_packet(data):
              # 将数据转换为字节
              data_bytes = bytes(data)
              # 计算数据长度 (新增)
              length = len(data_bytes).to_bytes(1, 'big')
              # 按协议格式拼接数据包: 包头 + 长度 + 数据 + 包尾
              packet = HEADER + length + data_bytes + FOOTER
              # 发送数据包
              bytes_sent = uart.write(packet)
              # 验证是否所有字节都已发送
              if bytes_sent != len(packet):
                  print(f"Warning: Only sent {bytes_sent}/{len(packet)} bytes")
              return True
          except Exception as e:
              print(f"Error sending packet: {e}")
              return False
      def pid_control(error, last_error, integral, Kp, Ki, Kd):
          """PID控制器"""
          proportional = Kp * error
          integral += error
          integral_term = Ki * integral
          derivative = Kd * (error - last_error)
          output = proportional + integral_term + derivative
          return output, error, integral
      def output_to_servo(output_x, output_y):
          """将PID输出转换为舵机控制信号"""
          # 限制输出范围
          output_x = max(-100, min(100, output_x))
          output_y = max(-100, min(100, output_y))
          # 转换为0-255范围 (128为中心)
          Servo_x = int(output_x * 1.28 + 128)
          Servo_y = int(output_y * 1.28 + 128)
          # 确保在0-255范围内
          Servo_x = max(0, min(255, Servo_x))
          Servo_y = max(0, min(255, Servo_y))
          return Servo_x, Servo_y
          target_valid = False  # 重置目标有效性标志
          # 目标识别逻辑
          black_blobs = img.find_blobs([thr_black], merge=False)
          if black_blobs:
              for blob in black_blobs:
                  if blob.pixels() / (blob.w() * blob.h()) < 0.3:
                      white_blobs = img.find_blobs([thr_write], area_threshold=2, roi=blob.rect(), merge=False)
                      if white_blobs:
                          largest_white = max(white_blobs, key=lambda b: b.area())
                          if (2 < largest_white.pixels() / blob.pixels() < 4 and
                              abs(largest_white.cx() - blob.cx()) < 10 and
                              abs(largest_white.cy() - blob.cy()) < 10):
                              target = [largest_white.cx() + target_offset[0],
                                       largest_white.cy() + target_offset[1]]
                              target_valid = True
                              # 绘制识别结果
                              img.draw_rectangle(blob.rect(), color=(255,0,0), thickness=2)
                              img.draw_rectangle(largest_white.rect(), color=(0,255,0), thickness=2)
                              img.draw_cross(target[0], target[1], color=(0,0,255), size=10, thickness=2)
                              img.draw_string(target[0]+10, target[1]+10, "(%d,%d)"%(target[0],target[1]),
                                            color=(255,255,255), scale=1.5)
          # 目标丢失处理 (与main.py保持一致的数据包格式)
          if not target_valid:
              send_packet([128, 128])  # 只发送两个舵机值
              print('Target lost!')
              continue  # 跳过本次循环剩余部分
          # 计算偏差量
          view_offset[0] += round((target[0] - img_center_x) * 0.5)
          view_offset[1] += round((target[1] - img_center_y) * 0.5)
          view_offset[0] = min(sensor.width(), max(0, view_offset[0]))
          view_offset[1] = min(sensor.height(), max(0, view_offset[1]))
          # 计算误差
          error_x = target[0] + view_offset[0] - img_center_x
          error_y = target[1] + view_offset[1] - img_center_y
          # PID控制
          output_x, last_error_x, integral_x = pid_control(error_x, last_error_x, integral_x, Kp, Ki, Kd)
          output_y, last_error_y, integral_y = pid_control(error_y, last_error_y, integral_y, Kp, Ki, Kd)
          # 转换为舵机信号并发送 (与main.py保持一致)
          Servo_data[0], Servo_data[1] = output_to_servo(output_x, output_y)
          send_packet(Servo_data)
          print(f"Sent: {Servo_data}")
          #print("FPS:", clock.fps()) 粘贴代码
    • @twph 和stm32通信控制舵机,根本没反应,ttl口也接收不到
    • 检查IO和接线是否有问题,OpenMV的TX连接32的RX,OpenMV的RX连接32的TX:https://book.openmv.cc/MCU/pyb.html
    • 应该是没问题,帮我看一下我的代码有问题吗?
