OpenMV可以给舵机输出正确的角度但是舵机为什么不动?
以下是main.py的代码:
import sensor, time from pid import PID from pyb import Servo # 舵机初始化(修改了舵机方向定义,添加初始位置设置) pan_servo = Servo(1) # 水平舵机 tilt_servo = Servo(2) # 俯仰舵机 # 校准舵机(标准舵机参数) pan_servo.calibration(500, 2500, 500) tilt_servo.calibration(500, 2500, 500) # 设置初始位置(重要!防止启动时抖动) pan_servo.angle(90) # 中间位置 tilt_servo.angle(90) # 中间位置 time.sleep_ms(500) # 等待舵机到位 # 红色阈值(保持原有) red_threshold = (13, 49, 18, 61, 6, 47) # 增强PID参数(大幅提高比例系数) pan_pid = PID(p=0.7, i=0, imax=90) # 水平PID(P值增大10倍) tilt_pid = PID(p=0.5, i=0, imax=90) # 俯仰PID(P值增大10倍) # 增益参数(新增) PAN_GAIN = 3.0 # 水平输出放大倍数 TILT_GAIN = 2.0 # 俯仰输出放大倍数 MAX_STEP = 25 # 单次最大变化角度 sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(20) # 增加跳帧确保稳定 sensor.set_auto_whitebal(False) clock = time.clock() def find_max(blobs): max_size = 0 for blob in blobs: if blob.w() * blob.h() > max_size: max_blob = blob max_size = blob.w() * blob.h() return max_blob # 死区阈值(防止微小振动) DEADZONE = 5 while(True): clock.tick() img = sensor.snapshot() blobs = img.find_blobs([red_threshold]) if blobs: max_blob = find_max(blobs) # 计算中心误差 pan_error = max_blob.cx() - img.width()/2 tilt_error = max_blob.cy() - img.height()/2 # 绘制识别框 img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(), max_blob.cy()) # 计算PID输出 pan_output = pan_pid.get_pid(pan_error, 1) * PAN_GAIN tilt_output = tilt_pid.get_pid(tilt_error, 1) * TILT_GAIN # 应用死区(误差过小时归零) if abs(pan_error) < DEADZONE: pan_output = 0 if abs(tilt_error) < DEADZONE: tilt_output = 0 # 限幅处理(确保每次变化不超过MAX_STEP) pan_output = max(-MAX_STEP, min(MAX_STEP, pan_output)) tilt_output = max(-MAX_STEP, min(MAX_STEP, tilt_output)) # 获取当前角度并计算新角度 current_pan = pan_servo.angle() current_tilt = tilt_servo.angle() new_pan = current_pan + pan_output new_tilt = current_tilt - tilt_output # 注意符号匹配硬件 # 最终角度限幅(0-180度保护) new_pan = max(0, min(180, new_pan)) new_tilt = max(0, min(180, new_tilt)) # 设置舵机 pan_servo.angle(new_pan) tilt_servo.angle(new_tilt) # 增强调试输出 print("误差: H={:.1f}, V={:.1f} | 输出: ΔH={:.2f}°, ΔV={:.2f}° | 位置: H={:.1f}°, V={:.1f}°".format( pan_error, tilt_error, pan_output, tilt_output, new_pan, new_tilt)) else: # 没有检测到物体时重置PID pan_pid.reset_I() tilt_pid.reset_I() print("目标丢失,PID重置") # 控制频率(约20Hz) time.sleep_ms(50)
以下是对应的pid.py代码:
from pyb import millis from math import pi, isnan class PID: _kp = _ki = _kd = _integrator = _imax = 0 _last_error = _last_derivative = _last_t = 0 _RC = 1/(2 * pi * 20) def __init__(self, p=0, i=0, d=0, imax=0): self._kp = float(p) self._ki = float(i) self._kd = float(d) self._imax = abs(imax) self._last_derivative = float('nan') def get_pid(self, error, scaler): tnow = millis() dt = tnow - self._last_t output = 0 if self._last_t == 0 or dt > 1000: dt = 0 self.reset_I() self._last_t = tnow delta_time = float(dt) / float(1000) output += error * self._kp if abs(self._kd) > 0 and dt > 0: if isnan(self._last_derivative): derivative = 0 self._last_derivative = 0 else: derivative = (error - self._last_error) / delta_time derivative = self._last_derivative + \ ((delta_time / (self._RC + delta_time)) * \ (derivative - self._last_derivative)) self._last_error = error self._last_derivative = derivative output += self._kd * derivative output *= scaler if abs(self._ki) > 0 and dt > 0: self._integrator += (error * self._ki) * scaler * delta_time if self._integrator < -self._imax: self._integrator = -self._imax elif self._integrator > self._imax: self._integrator = self._imax output += self._integrator return output def reset_I(self): self._integrator = 0 self._last_derivative = float('nan')
这是截取的一部分运行结果:
误差: H=17.0, V=-34.0 | 输出: ΔH=25.00°, ΔV=-25.00° | 位置: H=101.0°, V=96.0° 误差: H=13.0, V=-30.0 | 输出: ΔH=25.00°, ΔV=-25.00° | 位置: H=125.0°, V=120.0° 误差: H=3.0, V=-18.0 | 输出: ΔH=0.00°, ΔV=-18.00° | 位置: H=124.0°, V=137.0° 误差: H=-7.0, V=-2.0 | 输出: ΔH=-14.70°, ΔV=0.00° | 位置: H=108.3°, V=136.0° 误差: H=-18.0, V=7.0 | 输出: ΔH=-25.00°, ΔV=7.00° | 位置: H=82.0°, V=128.0° 误差: H=-23.0, V=27.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=56.0°, V=102.0° 误差: H=-29.0, V=29.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=30.0°, V=76.0° 误差: H=-39.0, V=30.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=4.0°, V=50.0° 误差: H=-43.0, V=32.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=0.0°, V=24.0° 误差: H=-50.0, V=30.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=0.0°, V=0.0° 误差: H=-48.0, V=30.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=0.0°, V=0.0° 误差: H=-48.0, V=30.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=0.0°, V=0.0° 误差: H=-47.0, V=29.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=0.0°, V=0.0° 误差: H=-43.0, V=29.0 | 输出: ΔH=-25.00°, ΔV=25.00° | 位置: H=0.0°, V=0.0°
