  • 为什么我按照视频里的训练,放进openmv中会显示这个
    • 0_1746626700853_15eb7933-ca20-4ea9-a4a1-cede2754f8bd-QQ_1746626695313.png !
      # Edge Impulse - OpenMV FOMO Object Detection Example
      # This work is licensed under the MIT license.
      # Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
      # https://github.com/openmv/openmv/blob/master/LICENSE
      import sensor, image, time, ml, math, uos, gc
      net = None
      labels = None
      min_confidence = 0.5
          net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
      threshold_list = [(math.ceil(min_confidence * 255), 255)]
      def fomo_post_process(model, inputs, outputs):
          ob, oh, ow, oc = model.output_shape[0]
          x_scale = inputs[0].roi[2] / ow
          y_scale = inputs[0].roi[3] / oh
          scale = min(x_scale, y_scale)
          x_offset = ((inputs[0].roi[2] - (ow * scale)) / 2) + inputs[0].roi[0]
          y_offset = ((inputs[0].roi[3] - (ow * scale)) / 2) + inputs[0].roi[1]
          l = [[] for i in range(oc)]
          for i in range(oc):
              img = image.Image(outputs[0][0, :, :, i] * 255)
              blobs = img.find_blobs(
                  threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
              for b in blobs:
                  rect = b.rect()
                  x, y, w, h = rect
                  score = (
                      img.get_statistics(thresholds=threshold_list, roi=rect).l_mean() / 255.0
                  x = int((x * scale) + x_offset)
                  y = int((y * scale) + y_offset)
                  w = int(w * scale)
                  h = int(h * scale)
                  l[i].append((x, y, w, h, score))
          return l
          for i, detection_list in enumerate(net.predict([img], callback=fomo_post_process)):
              if i == 0: continue  # background class
              if len(detection_list) == 0: continue  # no detections for this class?
              for x, y, w, h, score in detection_list:
                  print(f"x {center_x}\ty {center_y}\tscore {score}")
                  img.draw_circle((center_x, center_y, 12), color=colors[i])
    • 0_1746629890838_0c2378f7-8072-4ba1-933d-4f2488508a6a-QQ_1746629880349.png 这个为什么不支持啊🤔
    • 我还想问问,识别图像中,是不是只有神经网络模型的才能显示概率的,模板匹配没有对吗。
    • @swik 还有代码应该怎么搞😢
    • @swik 我感觉其实是支持的,那个什么英文网站可以训练 不过对个人用户有限制 且模型需要很轻量
      我已经想要本地训练了
