  • 追踪人脸时,我在检测到人脸的条件下,驱动直流电机,但是代码编写后直流电机工作,但舵机不会转动去追踪人脸了?
    • import sensor, image, time
      import pyb
      from pyb import Servo
      pan_servo=Servo(1)
      pan_servo.calibration(500,2500,500)
      pan_pid = PID(p=0.04, i=0.01, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      pinADir0 = pyb.Pin('P3', pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
      pinADir1 = pyb.Pin('P2', pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
      pinADir0.value(0)
      pinADir1.value(1)
      tim = pyb.Timer(4, freq=1000)
      chA = tim.channel(1, pyb.Timer.PWM, pin=pyb.Pin("P8"))
      sensor.set_contrast(3)
      sensor.set_pixformat(sensor.GRAYSCALE) # use RGB565.
      sensor.set_framesize(sensor.QVGA) # use QQVGA for speed.
      sensor.set_vflip(True)
          faces = img.find_features(face_cascade, threshold=0.75, scale=1.25)
          if faces:
              face = find_max(faces)
              cx = int(face[0]+face[2]/2)
              cy = int(face[1]+face[3]/2)
              pan_error = cx-img.width()/2
              img.draw_rectangle(face) # rect
              img.draw_cross(cx, cy) # cx, cy
              pan_output=pan_pid.get_pid(pan_error,1)
              pan_servo.angle(int(pan_servo.angle()+pan_output))
              chA.pulse_width_percent(40)
              chA.pulse_width_percent(0)
