  • 开机一段时间后摄像头捕捉到的画面色彩突然变得鲜艳 重新开机又变得暗淡
    • ![0_1565403972392_pink.bmp](正在上传 100%)
      ![0_1565404272650_pink2.bmp](正在上传 100%)
      为什么在摄像头捕捉到的画面中 两张颜色的鲜艳度差的这么多
      代码没更改过 期间只更换过小球
      摄像头开一段时间之后颜色就变得鲜艳 重新启动后又变得暗淡
          for c in img.find_circles(threshold = 1050, x_margin = 10, y_margin = 10, r_margin = 40,
                  r_min = 50, r_max = 200, r_step = 10):
              area = (c.x()-c.r(), c.y()-c.r(), c.r(), c.r())
              #img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆形用红色的圆框出来
              #area为识别到的圆的区域,即圆的外接矩形框
              statistics = img.get_statistics(roi=area)#像素颜色统计
              print(statistics)
              #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。
              #l_mode(),a_mode(),b_mode()是L通道,A通道,B通道的众数。
              if 0<statistics.l_min()<10 and 10<statistics.a_mode()<30 and -20<statistics.b_mode()<5:#if the circle is pink
                  img.draw_circle(c.x(), c.y(), c.r(), color = (255,0,255))#识别到的粉色圆形用红色的圆框出来
              elif 0<statistics.l_min()<20 and -5<statistics.a_mode()<5 and -2<statistics.b_mode()<2:#if the circle is white
                  img.draw_circle(c.x(), c.y(), c.r(), color = (255, 255, 255))#识别到的白色圆形用白色的圆框出来
              elif 0<statistics.l_mode()<20 and -20<statistics.a_mode()<40 and -60<statistics.b_mode()<35:#if the circle is white
                  img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 255))#识别到的白色圆形用白色的圆框出来
          #print("FPS %f" % clock.fps())
    • 此回复已被删除!
