  • 能不能详细解释下这段代码里的舵机控制部分(最后五行)?
    • import sensor, image, time
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      red_threshold  = (13, 49, 18, 61, 6, 47)
              max_blob = find_max(blobs)
