  • 运行测试的例程,openmv重新上电后,sd卡里的视频0字节大小,打不开?
    • import sensor, image, time, mjpeg, pyb
      RED_LED_PIN = 1
      BLUE_LED_PIN = 3
      sensor.set_framesize(sensor.QVGA) # or sensor.QQVGA (or others)
      pyb.LED(RED_LED_PIN).on()
      sensor.skip_frames(30) # Give the user time to get ready.
      pyb.LED(RED_LED_PIN).off()
      pyb.LED(BLUE_LED_PIN).on()
      m = mjpeg.Mjpeg("test1.mjpeg")
      #mjpeg.Mjpeg(filename, width=Auto, height=Auto)创建一个mjpeg对象,
      #filename为保存mjpeg动图的文件路径
      print("You're on camera!")
      for i in range(200):
      m.add_frame(sensor.snapshot())
      #mjpeg.add_frame(image, quality=50)
      #quality为视频压缩质量。
      m.close(clock.fps())
      pyb.LED(BLUE_LED_PIN).off()
      print("Done! Reset the camera to see the saved recording.")
      测试的例程,重新上电还是一样0字节
