  • 云台人脸追踪效果巨差
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      #pan_servo.calibration(500,2500,500)
      #tilt_servo.calibration(500,2500,500)
      #red_threshold = (13, 49, 18, 61, 6, 47)
      pan_pid = PID(p=0.17, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      tilt_pid = PID(p=0.085, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      sensor.set_contrast(3)
      sensor.set_framesize(sensor.B160X160) # use QQVGA for speed.
      sensor.set_vflip(True)
      降低环境因素的影响
      sensor.set_auto_gain(True) # 开启自动增益
      sensor.set_auto_exposure(True) # 开启自动曝光
          img.draw_cross(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2)) # cx, cy
      粘贴代码
