星瞳实验室APP,快速收到回复
  • 将lcd显示程序嵌套进追小球云台后虽然可以识别但是云台不转动了是怎么回事呢
    • import sensor,time,image,math, pyb,lcd
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      redthresholds = (20, 67, 40, 105, -28, 60) # grayscale thresholds设置阈值
      greenthresholds =(55, 71, -110, -13, -128, 127)#L亮度;a的正数代表红色,负端代表绿色;b的正数代表黄色,负端代表兰色
      bluethresholds = (57, 75, -34, -7, -79, 32)
      red_code = 1
      green_code = 2
      blue_code = 3
      sensor.reset() # 初始化 sensor.
      sensor.set_pixformat(sensor.RGB565) # or sensor.RGB565
      sensor.set_framesize(sensor.QQVGA) # or sensor.QVGA (or others)(QQVGA160120)
      sensor.skip_frames(10) # 让新的设置生效
      #sensor.set_auto_gain(False) # 关闭自动自动增益。默认开启的。
      lcd.init()#LCD的分辨率为128
      160
      clock = time.clock() # 追踪FPS
      return max_blob#定义最大色块未W乘以h
      image = sensor.snapshot().lens_corr(1.8)# Take a picture and return the image.
      blobs = image.find_blobs([redthresholds, greenthresholds], area_threshold=2000)
      print(blobs)
      x = blob[0]
      y = blob[1]
      width = blob[2] # 色块矩形的宽度
      height = blob[3] # 色块矩形的高度
      center_x = blob[5] # 色块中心点x值
      center_y = blob[6] # 色块中心点y值
      color_code = blob[8]
              if color_code == red_code:
                  pan_error = max_blob.cx()-image.width()/2
                  tilt_error = max_blob.cy()-image.height()/2
                  image.draw_string(20,0,"rect",color=(0,0,0))
                  image.draw_rectangle(max_blob.rect())
                  image.draw_cross(center_x, center_y)
                  image.draw_string(20,10,"w",color=(0,0,0))
                  image.draw_string(20,20,"h",color=(0,0,0))
                  image.draw_string(30,10,str(blob[2]),color=(0,0,0))
                  image.draw_string(30,20,str(blob[3]),color=(0,0,0))
                  lcd.display(image)#识别到矩形时才能显示,否则屏幕画面停留在之前的界面
