  • 测距时的Lm是什么意思?
    • 0_1565187964268_2699e9e6-e6c9-4efc-baa3-6c33b0cf0ae3-image.png 这里用颜色来测距时,Lm是什么意思,实际长度?那例程中的length也是实际长度啊,Lm=色块长加宽除以2又是什么意思呀?
      # Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      yellow_threshold   = ( 56,   83,    5,   57,   63,   80)
          if len(blobs) == 1:
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              length = K/Lm
              print(length)
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
